Old 11-01-2018, 10:02 PM
Dubis7's Avatar
Dubis7 Dubis7 is offline
Alchemizes cash to tubes
Originally Posted by Notimetolooz View Post
Your 8FQ7 are nearly all wrong! Did you measure the wrong tube?
I just double checked. Unless someone rewired this thing and moved one of the tubes, which I don't see any evidence of, it was definitely the right one. That being said...
When you measure the filament pins you need to use the AC volt ranges.
I had my multimeter on DC. Maybe that's part of the problem? I'll rerun my tests, but I'd better check out that Yoke first. Looks like Moyer Electronics has a replacement, but I think I'll try and resolder that wire first. Assuming it's just the lead that's broken off, would splicing a new wire onto that lead and running an extension to the terminal be alright? I get the impression that the winding pattern on the yoke is fairly significant to its operation.
While I'm at it, I suppose it would be a good idea to measure the resistance on the yoke. I imagine I can do that from the plug, but I'm not sure how to tell which lead is which. Any ideas?
To keep your tubes running smoothly, make sure to dust underneath the glass as well.
