Old 05-21-2018, 01:05 PM
Originally Posted by Wind157 View Post
I assume you think replacing the resistor will cause the vertical linearity problem to start occur again then?
It is possible but not guaranteed...Worry about having the parts meet spec before worrying about having it work perfectly...Otherwise, parts that have not been made in 50 years may be the next to smoke (due to bad caps, etc.)...
When I was a broke college student I used to try and get by replacing the minimum number of parts...So I can tell you from experience in most cases leave well enough alone (on old defective/risky parts ) = causing a worse failure in the near future.
