Thread Tools | Display Modes |
The frame is aluminum and the welds that hold the top on are mostly cracked...Since IIRC welding aluminum is expensive black magic I plan to do what a previous owner did on a cracked spot weld: drill a hole and bolt it together. I'll probably have to make some brackets to join it properly.
