Old 05-02-2018, 10:15 PM
Tom9589 Tom9589 is offline
I don't think that will work as the horizontal and vertical yoke windings are quite different in resistance and inductance.
Old 05-02-2018, 10:42 PM
I thought Josef meant swapping the horizontal wires (pins 5 & 7 in the schematic) with each other and then swapping the vertical wires (pins 2 & 6) with each other. (In other words, not swapping the pair of horizontal wires with the pair of vertical wires.) Or am I misreading one or both of you?
Phil Nelson
Old 05-02-2018, 11:23 PM
EdKozk2 EdKozk2 is offline
Tinker
Hi Phil,
Just reversing the two horizontal wire connections within the same circuit is what makes sense. The same would go for the vertical connections. One thing to watch for is if the picture is reversed. Lettering or words on the final viewed image will be incorrect. Just like putting a slide in a slide projector backwards.
Ed
Old 05-03-2018, 03:09 AM
Josef's Avatar
Josef Josef is offline
Exclamation
Originally Posted by EdKozk2 View Post
Hi Phil,
Ed
That's exactly what I wanted to point out. Sorry for causing misunderstandings- I'm not native speaker.
Old 05-03-2018, 06:12 PM
No problem! It's a clever idea. I may get a chance to try it in a day or two.
Regards,
Phil Nelson
Phil's Old Radios
