In Praise of Wooden Knobs
This post is about a mundane repair. I'm showing it here only because I found the outcome to be esthetically pleasing.
Horizontal Hold coil was controlled with a plastic rod attached with a metal tube. The coil-end attachment was loose and wobbly. When I was removing the HV cage I bumped it and it snapped off, flew into the air, it and I never found it. So I decided to replace it. with a long nylon alignment tool that would work perfectly. But... ![]() ...this cartoon inspired me to use wood (The Idaho Forests Products Commission points out that wood is an environmentally friendly, renewable resource). ![]() I had to cut the metal attachment. Readers from my generation will recognize the classic Tinker Toy construction. ![]() Finally, the hole did not align with the coil. The rod was flexible enough to reach the original hole, but it wouldn't turn freely, so I made a new hole. ![]() Ta-dah! ***I previously asked about the purpose of a short beaded chain attached to the HV cage. As it turns out, the end chain was broken but was originally to chassis. I think the purpose was to prevent a repair technician from forgetting to put the cage back.***
Winky Dink Damn the patina, Full speed ahead! |
