Old 03-05-2018, 02:34 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Originally Posted by dishdude View Post
Did you mean 2.6? The 2.5 is just a 2.2 with a larger bore and longer stroke with a balance shaft added. The 2.5 adds a lot of low end torque, and the balance shaft really smooths the engine out.
I meant 2.5, but I only have experience with one car so equipped and none with the 2.2 so I'm not really a good barometer. The head gasket cracked letting coolant into the oil, the timing belt broke and it blew a handful of frost plugs but never suffered any major damage. It was rather loud for a gas engine, noisy lifters maybe? It seemed sluggish sometimes but I reckon that had a lot to do with its temperamental 3-speed slushbox. If I recall correctly I often had to let up on the accelerator briefly to get out of low gear. I used to drive on a long stretch of level road and make a left at the end to go uphill; it wasn't very steep but that's when I would be mashing it and still be unable to keep up with traffic, no idea why.
Edit: Apparently the engine was getting tired, it sounded just like the one in this Aries (startup at 6:10).
