Old 02-15-2018, 03:11 PM
LADR's Avatar
LADR LADR is offline
Местное и дх радио
Seco HC8
I picked this up off PayBay for $5 and when it got here, I noticed that the needle was not pointing directly to 0. Normally, meters have a screw on the front to adjust the needle but mine doesn’t have this screw. What should i do?
Your good times will bring me down
Old 02-15-2018, 03:14 PM
LADR's Avatar
Местное и дх радио
No screw
File Type: jpg 59C074B7-5635-4799-8D7A-C73DFA516F1E.jpg (55.0 KB, 21 views)
Old 02-15-2018, 04:35 PM
Personally if it works I'd leave it alone. On a scale of 0 to 300ma the error is insignificant. If it absolutely bothers you, you could possibly remove the plastic cover and bend the needle. But it would be my luck that I'd slip and bugger something up much worse.
[edit] It could even be the paper dial scale was misplaced, but I'd still leave it.
Old 02-15-2018, 07:21 PM
LADR's Avatar
Местное и дх радио
I thought about putting in a meter with a screw but i dunno.
Old 02-15-2018, 08:31 PM
Maybe the screw is on the back...
Old 02-15-2018, 10:13 PM
LADR's Avatar
Местное и дх радио
Nope. Nothing like that.
Old 02-18-2018, 10:42 AM
Originally Posted by LADR View Post
No screw
By the picture shown, it looks like the plastic lens snaps off and the adjustment is inside on the needle pivot.
It would probably be easier to remove the meter movement from the instrument and there should be small screwdriver slots to pop the lens off.
Be extremely careful, as meters can be damaged easily.
Old 02-18-2018, 11:22 AM
WISCOJIM WISCOJIM is online now
I have two of these, and I looked at them yesterday to see if the meter cover would pop off. I used a fair amount of force, and neither budged. I was afraid to try to pry them off.
Old 02-18-2018, 11:38 AM
Hopefully, they weren't glued on! That's why I suggested removing the meter. It would be a little easier to see what's going wrong.
BTW, 5 bucks was a good deal!
