It seems it should be possible to re-attach the safety glass with the same material used originally, or it's modern equivalent.
The problem is it's probably not available to the general public, and if it is it's probably only sold in 55 gallon drums or larger. |
Even if you could get the proper resin to do the rebonding, it likely needs to be done under vacuum to prevent entrapping air bubbles between the faceplate and the tube.
