Old 01-20-2018, 03:47 PM
SueAnders's Avatar
SueAnders SueAnders is offline
here's some clearer pictures of the "innards"
including the chassis and inside stuff:
Happy Motoring!!
Old 01-20-2018, 03:53 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
It looks like it is not a remote set as I don’t see the large remote chassis.
Old 01-20-2018, 04:04 PM
Is NOT a remote set, just motorized VHF tuner. It does have a UHF
tuner. Even if it were hidden the green antenna wires are a give away.
Zenith always used brown for VHF & green for UHF.
You can see the dial lamps & numbers disks also. The mystery is
where the hell do the numbers shine through ????
Maybe its got the wrong knobs ? When I get chance I will look
in the line folders......
Old 01-20-2018, 04:08 PM
compucat's Avatar
1949 Motorola 9VT1
I see a rectangular cutout in the metal control panel for the numbers but it is covered up by the wood grain decal that says color on the front panel. I really wonder if this set has the correct knobs for the volume and tuning. Shouldn’t the volume knob have the tri-color logo?
Old 01-20-2018, 04:19 PM
It will shine through that slightly translucent grain. They would not have included internal number wheels if they were going to use numbered knobs.
Old 01-20-2018, 04:22 PM
compucat's Avatar
1949 Motorola 9VT1
I would like to see it on to know how well those channel numbers show up through the decal. It is a neat idea, though. My set has the channel numbers viewed through the center of the tuning knob.
Old 01-20-2018, 04:26 PM
I have an older (probably from a 29KC20) power tuning tuner cluster and it's bezel in my spare tuners box. It has that plastic wood grain and IIRC I once powered the dial lamps and found it was viewable in normal room lighting...It is kind of unexpected and cool to see it shine through when you don't expect it to.
Old 01-20-2018, 04:33 PM
WISCOJIM WISCOJIM is offline
Just an FYI, no vitriol intended...
Sue, you get some leeway here because you are new, but it's bad procedure to start so many threads about the same TV in the same forum.
It makes it terribly difficult to keep track of what happens to the set between when you first saw it until we finally get you through restoring it to a functioning and reliable TV. It causes us to miss what you did in earlier posts, which may be vital to help you in later ones. For example you have now placed pictures of the set in a thread. Later we might have to locate them again to help you with a future problem. All in one thread makes them easy to find. It's to your advantage to keep the story flowing smoothly.
To the moderators: Any chance one of you could come and combine 4 of these threads? The other two in introductions and classifieds are indeed separate.
Old 01-20-2018, 04:38 PM
SueAnders's Avatar
Oh I'm sorry, I'm new to this! Can someone please put everything all together as has been suggested? it does make sense in this case. The vintage home an car sites are very differently structured! Henceforth I will just continue on with this thread then.
Happy Motoring!!
Old 01-20-2018, 04:17 PM
I don't see a remote chassis (though IIRC it was usually hung from the top back of the cabinet which is not pictured), and lack of text reading "Space Command" on the front leads me to believe it is a Non-remote set with motorized tuning.
