Old 01-05-2018, 02:22 PM
Centering magnets are on the back of the yoke. They are the rings that the neck passes through they have two ears to grab and rotate. The centering rings affect both horizontal and vertical centering simultaneously.
Not in a Predicta. Phil put up a scan on his website showing the locations. There are two magnets you can rotate for the centering.
The "T" bar on the left can be push forward and pulled back to adjust the horizontal linearity. Twist it a little for distortions in the corners. It's crude for sure so don't expect perfection.
Here's the whole article: https://antiqueradio.org/philc12.htm
