Old 12-18-2017, 03:50 AM
1911nutjob 1911nutjob is offline
Since the conversation has shifted focus to compactrons, I guess now is the time to ask. Can you guys recommend a compactron tester I could find easily on fleabay? If one tube goes bad I don’t want to do the Christmas light trial and error thingy. Series string isn’t something you typically see on the hifi side.
Old 12-18-2017, 10:36 AM
A tube manual and multi-meter set on ohms or continuity is all you need to find an open heater. Compactron tubes, the heater pin are 1&12, either side of the gap.
Re: the tube checker! A Sencore Mighty-mite or other modern tube checker that has Compactron and Novar sockets would do fine.
I bought a full compliment of tubes for my PortaColors, except the 12JF5 for a buck each from ESRC, dollar-days list.
For the damper tube I use a 19CG3 instead. It's a better tube and two extra volts in the heater string is better.
Old 12-18-2017, 11:45 AM
maxhifi's Avatar
maxhifi maxhifi is offline
since the conversation has shifted focus to compactrons, i guess now is the time to ask. Can you guys recommend a compactron tester i could find easily on fleabay? If one tube goes bad i don’t want to do the christmas light trial and error thingy. Series string isn’t something you typically see on the hifi side.
eico 667, that's what I use and I am very happy with it. If you don't plan on getting too heavy into this, a spare set of tubes you can substitute in as required would be much cheaper
