Old 08-12-2017, 11:38 AM
...the heater string... does not need to be wired with the tubes in any fixed order.
Um.. by convention, in a series heater string, the first audio tube is usually at the bottom (ground) end of the string to minimize hum pickup. The OP might want to verify that the 1st audio tube's heater is indeed at the bottom of the string, in regards to his hum problem.
(Edit) Also, the rectifier (e.g., 35W4 etc.) is conventionally at the top of the heater string to minimize heater-to-cathode voltage. The audio output (e.g., 50C5 etc.) is usually the next one down the string.
