Old 08-06-2017, 06:54 PM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
So I put it on the variac and after maybe an hour and a half I was up to 100 volts and the 6CB5 started to red plate in the middle of the plate (No HV either). The set is missing most of its tubes, but I did have in the HV cage tubes, the damper, the H out tube, and the vertical out tube. I forgot to add the horizontal multiplier tube so that may account for the red plating 6CB5 and lack of HV. Current draw was about 2.5 amps and normal current is 3 amps at 117v. I must say I am very weary of applying full line voltage to the set with all the original filters, but I need to see if the Jug is gassy (Which I dont think it is.)by applying some HV to it. Everything else seemed to be normal, no burning smells and the power transformer only got lukewarm after being on for an hour and a half.
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
