Old 06-30-2017, 01:12 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Ahhhh, I didn't look closely enough at the chart at first, it is indeed a 19QB.
That's awesome about the parts, much appreciated. I suppose the fine tuning knobs could easily be electroplated. The channel knobs, well, good luck restoring those. Also, I don't think I'll need to transplant anything; the ends of the shafts are about 1/8" below the trim panel. The socket does use female chassis connectors, those for the focus and filament leads being different. Both filament leads are attached to the same plug and the focus lead terminates in something that looks like an in-line fuse holder. The EIA number is a match and the patent number on the original is 3251016-337612.
I just realized, the knobs that came with it aren't even a matched set. The VHF knob is probably from a smaller set. I noticed the legend dial diameter difference right away, but now I see the VHF knob lacks the raised V-shaped section and is more chunky.
