Have you checked the high value resistors on the reg tube? If it uses two 1.5M resistors they need to be a matched pair.
You may want to look into upping that B+, either by removing load from it or perhaps connecting the set to a variac and cranking the line voltage to the set a bit above what is coming out of the outlets. Remember conduction is determined mostly by the G-K voltage difference. Also if you have a service manual for that set it likely will tell you how to measure reg current off of resistors in the circuit...That info may help.
But there must be a reason the B+ is low. I think the boost is okay on the G but the B+ on the cathode is low. Another thought. Originally it had two 160 Mfd caps off the secondary between the rectifier diode and ground with the other side of secondary tied to junction of the two caps. He changed these to 180 mfd. But I wouldn't think that would make this much difference. It only has half wave rectifier.
