Old 05-01-2017, 10:18 PM
Emits low whistle...A few more coats of lacquer and you'll probably be able to shoot it and not hit wood.
Looking good so far.
Yeah, the lacquer is on a bit heavy. There's a reason for that though. In a nutshell, I screwed up a bit and ended up wiping some of the grain filler away. The front and top could not go through a sanding again because the veneer was very thin in places. So the only thing that I could do is load up on the clear coats, sand, more clear coats, sand, etc till the surface was smooth.
Then I had a problem with the decals (self induced) and had to redo the left side which needed the lacquer built back up till the decals disappeared.
Over all, it is looking good!
I'm leaving for ETF on Wednesday morning so tomorrow will be the last day to shoot some "final" clear. Otherwise I'll have to wait till I get back.
