Old 04-02-2017, 05:15 PM
decojoe67's Avatar
Cute '39 RCA "Little Nipper" 9TX-33
I hesitated getting this little deco set because it had what looked like a very faded worn finish and the seller said that although it had been recapped, it stopped playing. I went for it and not only did the cabinet refresh to a beautiful sheen, but the after a little fiddling with the chassis it worked perfectly! Not a bad little player too. This model shares the same chassis as the famous '39 Worlds Fair models and is only about 9/12" long and weighs about 5lbs.
Old 04-02-2017, 09:25 PM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Noice.
Old 04-03-2017, 02:45 AM
Titan1a Titan1a is offline
Tastefully done.
Rick (Sparks) Ethridge
Old 04-03-2017, 04:39 AM
decojoe67's Avatar
Originally Posted by Titan1a View Post
Tastefully done.
Thanks. My trick is to rub in some stain before using Howards Restore-A-Finish. Also, after the beeswax application, I mist some furniture polish on cheesecloth and buff to a nice glassy shine. It lasts for a while too!
Old 04-03-2017, 03:06 PM
maxhifi's Avatar
maxhifi maxhifi is offline
That's a very attractive late 30s radio, great find.
Old 04-03-2017, 09:00 PM
Wow, never seen that one! A magic time in the radio business.
Old 04-04-2017, 03:01 AM
Tubejunke's Avatar
I've never seen one of those either. Just when you think you've seen it all!
Old 04-04-2017, 03:59 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
Excellent!
Old 04-04-2017, 05:08 AM
decojoe67's Avatar
Thanks guys. I should've put something in the picture to show how small it is. That's the most appealing thing about it. The little ribbed knobs require you to use your fingertips. I like that it has a lit dial too. RCA actually made a whole slew of plastic and wood "Little Nipper" models at this time.
Old 04-04-2017, 11:50 AM
Great find! I have never seen that model. I have what is likely the most common model, in brown bakelite, with two tiny knobs. Like this:
http://www.radiomuseum.org/r/rca_45x1_1.html
Very compact design for a AA5 using octal tubes, mine measures about 8.5"x 5"x4", not counting the knob depth. The tiny Knobs are a little over 1/2" in diameter. Decent playing little set and soooo cute.
The Smithsonian site shows a SW version with direct tuning knob:
https://www.aaa.si.edu/collections/i...hn-vassos-8191
All are very desirable.
Old 04-05-2017, 04:07 AM
Tubejunke's Avatar
I think I have the same one that jr tech has. I used to think that the tube heat would be too much for the case, but it does just fine. Not beautiful, but very interesting.
Old 04-06-2017, 07:59 PM
decojoe67's Avatar
I've found that certain vintage radios and TV's that may not necessary impress in a photo look awesome in person due to their size. As is the case with this RCA, if it was a standard sized tabletop it would be rather plain, but when you see this little set in person, in which you can easily grasp and pick-up with one hand, it becomes so appealing! Amazing how it survived all these years with very little signs of wear being it was likely a child's radio!
Old 04-14-2017, 10:41 AM
electronjohn's Avatar
I like....big sparks!!
That's pretty nifty!
Ham shack...AM side: Knight-Kit T-60, RME-45
Vintage SSB side: National 200
Modern SSB: Kenwood TS-180S
MFJ tuner, 130' dipole
Old 04-14-2017, 12:03 PM
Can't get the picture but the SW version with the direct tuning was built by Detrola, for RCA. All metal tubes and a line-cord resistor.
The radio shown, must be one of the first to use the 150ma tube series.
The earlier run of the Little Nipper series used 300ma tubes and a line-cord resistor. Some used a 6A8 converter tube. That model was RCA built.
Old 04-14-2017, 03:12 PM
decojoe67's Avatar
There's another rather rough (and pricey) one on eBay now:
http://www.ebay.com/itm/RARE-RCA-9TX...sAAOSwKfVXF~km
