Old 07-17-2016, 07:06 PM
davet753's Avatar
davet753 davet753 is offline
David Thomas
Out of curiosity, what do people dislike about the yellow caps?
I'm wondering the same thing. I've been using the yellow caps for several years now, and have yet to run across a bad one. Naturally, I would prefer Sprague orange drops, but the yellow capacitors cost SO much less!
Old 07-17-2016, 07:10 PM
Old TVs are better!
For a 1951, the chassis looks clean and rust free. That's a plus for sure. Except for the top, it looks like it's a good candidate to restore and re-cap. Some scratch polish or some stain should take care of that. I don't see why it wouldn't be as good as any set of that era. I don't think any CRT set with magnetic focus looks as bright and sharp as those using the "newer" electro-static focus. Looks to be an easy set to work on and re-cap. Orange drops are good capacitors and I understand the yellow ones work well also. However orange drop caps are on the more expensive side. I use capacitors from capacitorworld dot net and have had very good luck using them. BTW they are brownish/red in color not yellow. I wouldn't worry a whole lot about the variance in the readings on the B&K CRT tester. The tester is probably working fine. The tube should "wake up" fine once you are able to get the set recapped and going again.
Old 07-22-2016, 07:18 PM
TUD1 TUD1 is offline
I took the chassis out of the set so I can begin work on it tomorrow. Holy moly at all those caps...
Old 07-22-2016, 08:07 PM
miniman82's Avatar
First Light: 1952-2011
I had a chassis from around the same period, but it had a 19" metal CRT in it. No matter what I did it was just unstable on the horizontal oscillator, seemed like crappy build quality anyway.
Evolution...
Old 07-22-2016, 08:37 PM
cluelessgame cluelessgame is offline
I'm pretty sure that's the same model TV that was in Doc's living room that started playing Howdy Doody in Back to the Future Part II
Old 07-23-2016, 07:42 PM
We made a little bit of progress on my RCA KCS-47 today at the radio club. I meticulously checked each individual tube with a military tube tester, and after two hours, replaced all the weak ones. Amazingly, the 6BG6 tested perfect. We also replaced a 180 pF capacitor in the horizontal circuit with a silver mica. My friend who knows these things won't be there to help me next weekend, so I'm just going to change the lytics out.
Old 03-31-2017, 03:36 PM
The KCS-47 has now been 100% recapped. It's been that way since New Years, but I haven't been able to work on the set at all because of all the junk everywhere. I put the chassis back in, got a converter box, and this is the image I saw. It also has intermittent video, where sometimes, it won't diplay an image at all. Just a grey screen with retrace lines.
Old 03-31-2017, 03:39 PM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
We tried to tell you
Good effort so far though!
Old 03-31-2017, 05:41 PM
If that's the image a KCS-47 produces, what's the point of buying it in 1951?
Old 03-31-2017, 07:04 PM
That image was probably taken from a set which was far from being in peak operating condition, with leaky or open capacitors and such; however, some people will watch their TVs with absolutely terrible pictures (oversaturated colors, too bright, shrunken ...), and won't mind it a bit, as long as they can see their favorite shows. (I knew a family some years ago who was like that.) Don't forget, television was still a novelty in the early 1950s. The state of the art was nowhere near as advanced in 1951 as it is today; everyone had to make do with what was available at the time. This means that even when the set was in perfect (!) working order, it still did not produce that great a picture by today's standards; however, given the state of the TV art in the 1950s, the picture may have been regarded as very good.
The KCS-47 chassis can produce excellent pictures (given a decent signal), and it probably did when it was new. I used to watch one years ago (long before DTV); it had a great picture on all three (at the time, 1970s) Cleveland VHF television stations and using rabbit ears as an antenna.
Remember that VHF television stations in the 1950s did not have much power (this was long before the age of super-power UHF stations with signals in the megawatt range). Most folks used outdoor antennas to get the signals, although if you were close to the towers (within twenty miles or so), you could probably get by with rabbit ears. I had an aunt who lived in Independence, Ohio, which is quite close to Cleveland's TV towers; she could get every Cleveland station in color just by using a short length of wire on one of the antenna terminals. My grandmother, who lived in the city of Cleveland near the suburb of Shaker Heights, got excellent reception of all three network stations on her '51 GE 16" console, using only rabbit ears, in the 1950s until she got a color set in 1969. Even then, she was getting excellent color reception, even on the PBS affiliate (then NET), with just an indoor antenna.
Of course, these days, with almost all TV being on cable and/or streaming video, the reception issue is fast becoming a moot point. As I read in an issue of TV Technology a few minutes ago, before starting to write this, the FCC wants to eliminate broadcast TV altogether, since so many folks are watching TV via the Internet and other platforms which do not rely on RF signals.
The day may come when there will no longer be any such thing as over-the-air television. I think that day may come sooner rather than later, given the popularity of streaming video over the Internet. I personally do not watch OTA TV anymore, since getting a Roku player over a year ago (I upgraded mine late last year, and still have my first one). I hooked up the little box to my 19" flat screen and did not look back. The only reason I have a cable account with Spectrum (formerly Time Warner) at all these days is so the Roku Spectrum TV app will receive local channels. No cable account (the cable need not, however, be physically connected to the television), no local TV. That's just the way it is and has always been with this cable operator. I think (in fact, I am almost certain) they are doing it this way to be able to pay for the privilege of carrying local TV signals (in any area served by Spectrum, not just northeast Ohio) through the Spectrum app. They could never get away with it otherwise.
Old 03-31-2017, 07:51 PM
Someone on ARF (Bill Cahill?) had something like a 15 page thread on their repairs on one...Every time they had it working decent something new would blow or burn...I don't think you could give me one of those sets.
Old 03-31-2017, 08:24 PM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
It seems like RCA's sets from about 1949 to 51 or 52 were pretty crappy build quality and not well designed. The KCS-49 being a great example of this. Things started picking up though when RCA got into color sets I believe.
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
Old 03-31-2017, 08:32 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
First, monochrome television had reached an incredibly high standard by 1951. Hell, by 1939 even. Anyone who has watched a TRK-9 knows that even some prewar sets were capable of a brilliant, bright, contrasty, B/W picture on par with a postwar standard of excellence: the 630TS.
RCA experimented with some chintzy designs in the 1950 and 1951 model years; ultimately the bean counters run the show. The KCS-47 chassis was all about cost cutting. That said, RCA did have some quality designs in the same period: the RCA 9TC275 had a fine chassis (number escapes me at the moment), and the KCS-66 sets are a veritable gold standard. Monochrome television was a mature technology in 1951; RCA was just trying to move a greater volume of sets at a lower cost. It's simple economics.
Look at the devolution of RCA BC band radios. The Radiola 60 was a fairly high quality radio: RF amplification, extremely sensitive when properly aligned. It can recieve anything right down into the atmospheric noise. It wasn't perfect, it had a low IF frequency thus it had image issues, but it's otherwise a great set.
Now look at the typical AA5, of which RCA built millions. No RF amp, noisy converters, a single stage of IF amplification. The only advantage over the Radiola 60 is the higher IF frequency.
Why the devolution? Cost cutting. Fewer tubes, newer tube types, smaller radios in cheaper cabinets. Follow the almighty dollar...
Old 04-01-2017, 01:09 AM
colorfixer's Avatar
Probably bean counters saying "build'em cheap and quick and get them out the door" before color came into being. They had such high hopes for color in the 50's. Then there was the General's edict to flood the market with as many monochrome sets as they could before CBS got a foothold with their sequential color...
Old 04-01-2017, 03:14 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
From the picture, this set looks exactly like mine. Does this mean mine has a shit chassis too? sadface
Honestly I have no experience with these old tvs yet, but mine looked like an electronically-well-made set. But what do I know?
