Already starting to have a slightly annoying problem with this thing. The brightness and tint knobs are concentrically centred, and even though I put some lubrication in there, the two knobs are sticking together. And also the convergence has already drifted WAY off just in the two hours since I finished it. Guess I know what I'm doing tomorrow afternoon.
Seems odd that the convergence would go off on its own for no reason. Did you by any chance move the TV? Changing its orientation (for example, rotating 90 degrees in a room) can mess up the purity, as I learned once when I moved my first CTC-11. The result isn't the same as bad convergence, but it can give you some weird colors.
Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html
