Old 03-07-2017, 05:58 PM
You see the ~4 dashes above the man's head, and the 1 above the kid's head? those are closed captioning data which is placed at the VERY top of the picture...The bright part of the picture should be ~3-10 horizontal scan lines away, but is is not (it is much farther). Your video source is giving you a letter boxed and pillar boxed signal (you can see the extra horizontal black bar faintly on the left side as well). It looks like the below where the picture is shrunk by the signal source and black is added around the edges (please excuse the lack of right perimeter VK's posting system dislikes ASCII art making a right border impossible).
Code:
_______________
| b  ___________
| l | picture
| a |
| k |___________
|______________
Tom,
You're right! Duh. However the problem (if it is a problem) I think I'm having is that there is too little height to the overall picture.
Old 03-07-2017, 06:02 PM
Here another picture of the problem I'm having. I have the brightness turned up pretty good and reduced the contrast pretty low so the quality isn't that good. You see that portion at the top of the picture? Loos like it is scanning but not "painting" anything worth seeing. If it would be painting the picture would be a lot larger. Do you think that doing a full alignment help. I plan on doing one anyway.
Old 03-07-2017, 06:09 PM
Keep in mind this set has a pretty small viewing area. The 4:3 rectangle should almost fit entirely within the CRT face. Only a little of the corners gets clipped. You've got too much width and height. I think that might just be the retrace blanking interval on top.
Old 03-07-2017, 06:46 PM
Bob,
I think I forgot about the small viewing area. Though I have seen Youtube videos fill the entire screen area. In any case I put the mask up against the CRT and centered it and here's what I have now:
I think I'll move on to aligning the thing.
Thanks guys.
Old 03-07-2017, 06:54 PM
That looks good. If you want a big round picture you need to get yourself a Zenith Porthole.
BTW a lot of pictures have gone missing at the beginning of the thread.
Old 03-08-2017, 05:57 PM
I thought I'd show everybody how I attach the power cord to the HV cage. The previous "technician" had replaced the cord and used JB Weld to hold in the original drilled out rivets. Of course he used way too much and I had to grind out a lot of the JB Weld.
I get the small plastic spacers and rivets from my local ACE hardware store. They are in those bins that are along the hardware aisle. I used plastic spacers that are 1/4 long, 1/4 diameter, with a #6 screw hole. The rivets are 1/8 diameter and 3/8 long. The rivets are a solid shank except for the last 1/16 inch or so.
I use my heat gun to gently soften the plastic ears and insert the plastic spacers into the plug. If you have a keen eye, you'll see that one of the spacers is for a 4-40 screw while the other is for a 6-32 screw. Later on I removed the 4-40 spacer and inserted a 6-32 spacer. A 4-40 spacer is too small for the 1/8 rivet to pass through.
I also use a 4-40 fender washer under the head of the rivet. Here you can see how much of the rivet needs to protrude through the HV cage. Not much at all.
Once the rivet with the washer is in place, I put the head of the rivet on my bench vise anvil and support the HV cage using empty chip dip containers stacked to the correct height to have the HV cage level. I then use a small tack hammer and a center punch to begin to flare out the rivet. The center punch is the type that is pretty "blunt". Once the rivet firmly set with the center punch, I use a domed shaped bolt head to finish flatten out the rivet. You don't have to beat these rivets real hard. Just some gentle taps with the tack hammer. Here are the tools I use to set the rivet.
Here is what it looks like when I'm done setting the rivets.
And the finished product.
Old 03-09-2017, 12:38 AM
I need some help guys. I'm reproducing the labels for this TV. I'm doing the label that goes on the back of the chassis that is a "Caution" label warning not to service the picture tube. I'm guessing that in the lower right hand corner is some small numbers that designates the part number of the label. My label was deteriorated enough that those numbers are no longer with the label.
Is anyone out there that has a 621TS that has a good label that could get me those numbers? Maybe the RCA 630TS sets had the same label?
Thanks.
Old 03-09-2017, 03:21 AM
Tim's Avatar
Tim Tim is offline
932023-1
Tim
Old 03-09-2017, 10:53 AM
Originally Posted by Tim View Post
932023-1
Thank you Tim.
I have what I need now.
Old 03-09-2017, 11:02 AM
On a slightly different note.
I've read about a database listing all the 621TS known to be in existence. Does anybody know where or who is keeping it?
Old 03-09-2017, 11:44 AM
I was keeping a list but it got to be too much hassle.
Not the least of the problems was the lack of serial numbers from many submissions, without that there's no way to tell if a listing is a duplicate of a set that changed hands.
Old 03-09-2017, 03:42 PM
OK Eric. I could see that would be a real hassle if s/n weren't provided.
Mine is C 003445. I was wondering if it was on the list?
Old 03-10-2017, 10:26 PM
My high voltage caps came in for the doorknob cap.
It was a tight fit because I didn't want to grind out any more than I had too. I used a 1000pf 10Kv cap with a 25-40% decrease of capacity at rated voltage.
I epoxied on the bottom plate and that is curing while I type.
Old 03-11-2017, 11:47 AM
I would be leery of re-using that casing because of leakage concerns.
You're right! In full disclosure the re-stuffed cap leaked. I didn't even mess with it. I took it out and replaced it with a similar cap. Oh well.
Old 03-11-2017, 11:04 PM
decojoe67's Avatar
It certainly was a good try! I'm a novice, but would've expected it would have worked.
