Repair tips for RCA VCRs
Dunno if this will help anyone, but here's a consolidated list of repair tips for RCA VCRs I collected back in the day - various sources, some from RCA, most from the web.
Brian USN RET 22YRS (Avionics/Cal) CET-Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! Last edited by Findm-Keepm; 09-29-2017 at 06:39 PM. |
Thanks for all the additional info, guys. Finally got under the hood; nothing looks bent/broken and head drum appears undamaged (although my magnifier isn't great). So, fingers crossed it wasn't a fatal drop.
Belts are all intact but one or two look pretty tired. Haven't run it open yet to see exactly what's slipping or stuck. That's next, though I'll likely swap belts regardless as preventive maintenance. Going rate for the PRB kit is $20... I gather I should get that and not mess with anything generic/cheaper. Quote:
One more general question related to this make/ model/ era, for anyone: Even if I manage to clean & restore this thing to good-as-new factory spec, did older consumer VCRs inherently cause more wear & tear on tapes? I know playback will never match a modern JVC or Panny SVHS deck but I'm more concerned about how rough it is on the media. |
With new or like-new heads, no problem. Get it gunked up, and it'll wear tapes out fast - first to go is the sharpness of the picture. Think of the old kiosk VCR-tape loops playing in Sears, JC Penney and Montgomery Wards back in the day - most looked smeared and lost color in the pix. Worn tape from 3,000+ playings. Need a head? Dunno if Asti Magnetics still has them for the older stuff, but you can try. They may have gotten stuck with a bunch... Heads were about 20 bucks back in the 90s from Asti - some even cheaper. 4-Head? $$$$...
Others to try: MAT Electronics ACME Electronics <- no more......gone entirely from the web. MCM Electronics <- they've gone corporate, so who knows if any old stuff is still around. I LOVED them in the 80s.
The 2-head drum in my RCA doesn't *look* gunked up, although I cleaned it using cardpaper + 99% isopropyl and got a lot of stuff off.
Asti does have a replacment head P/N for mine but unclear if it's actually available. Gotta contact them directly I guess; will see what they say. If they have one and it's cheap enough, would be nice to play old tapes on this thing without fear of degrading them. Thanks for the hint! |
