#61
I can understand your caution, but eventually that is something all of us will not be able afford as replacement CRTs dry up. Any implosion with or without safety glass is going to throw glass out the front of the set. Members here have told stories of mid 50's sets with separate glass as well as color tubes with bonded glass spontaneously imploding and throwing glass out the front of the set. Any set even untouched factory originals have some chance of imploding spontaneously...In 99.99% of CRTs implosion is either an act of god of an act of the human(s) around the CRT when it goes off. The only way to 100% avoid it is to not own pre tension band era CRTs.... They way I see it if a CRT is no more dangerous than other models I have that are ~10-20 years older then it is plenty good enough. I never let implosion (on completed sets) worry me...Hell, I've got a caulked rectangular tube within ~3' of my bed and am around it 6-24 hours a day every day except ~2 weeks of the year vacationing. I'm more likely to be struck by lightning than even mildly injured by an implosion from a de-catted CRT that is mounted in a TV....Implosion injury during the removal process however is a lot more likely than lightning especially RCA tubes that require heating.
#62
I never saw removing a cataract and only sealing the edge as a good solution. I admit I have done this myself in the past, but have always had serious safety doubts. The way safety glass is made is to have a plasticized layer between two sheets of glass. It is this middle layer that makes it safety glass. That layer is what holds it together so that glass doesn't fly around in loose pieces. When you remove the bonding agent, you have just ended up with two individual pieces of glass, free to shatter and fly wherever. Remember that the bonding was there for more than just to hold a cover glass in place. It was to create a safety glass by bonding the cover glass and the CRT face together. Removing the bonding agent and not replacing it gives you very little implosion protection. . |
#63
main point is to the OP, just be very careful, you can become complacent (I did) with success to the point of not exercising real caution. Lots of ways you can get hurt by these old TV's CRT is just one of them.
#64
It's a false sense of security with having an intact safety glass bonded to the CRT, as implosion protection with bonded safety glass is only present from the front and when the CRT is installed. Anytime a CRT is removed from the cabinet, all of it poses a serious implosion threat. Glass shards from an implosion fly everywhere, and have no care for whatever is in their way.
Having had a 25" CRT implode just inches from me, I can tell you I now take every measure of safety seriously. Be v-e-w-y careful, as Elmer would say....
#65
#66
#67
It was in the 80's today, so I decided it's a nice day for another cataract surgery. This time, I put the tube in the hole I dug with a tire, instead of on the bathroom floor. Once again, I got the glass and glue off very easily. The glue came off again in one big sheet.
#68
Just siliconed the glass back on. I put the silicone on a little heavy in a few places, but it's beacause it's dark outside now and I couldn't see.
#69
Here's how the siliconed tube looks with the mask over it. Not nearly as bad as a cataract, but still noticable. I might get a razor blade and cut the silicone and try again.
#70
I've always wanted to try PVB resin to tack the safety glass back on to the face of the CRT. Something like this:
http://www.ebay.com/itm/Re-Repair-Re...4&var=&vxp=mtr I have no idea what version of the stuff I'd try - or what "CPS" is... I'd go with just a thin line along the edges, and lower the safety glass onto the CRT carefully. It cures optically clear, so not much "show" and the safety plate would be within a millimeter of the CRT face, so no "shadow effect" caused by a gap. My 21FJP in my CTC16 has a cataract, but it's in storage right now, so I'm a long way off from trying.
#71
From what I can find, cps stands for centipoise, a measure of viscosity.
#72
Maybe fasten the glass back on using a few small evenly spaced pieces of double sided tape, then follow up with a fine bead of caulk around the outside to seal the dust out, or maybe even just use clear tape. I highly doubt silicone caulk will add much implosion protection. I'm thinking avoid the whole caulk mess.
#73
I just use the foam tape, single side sticking, go all around the glass (not the crt) and use packing tap to hold it in place. The foam tape spaces the glass off the crt, keeps the dust out.
#74
I've always preferred caulk. If done right it won't be seen, and it should last the life of the tube...Unlike tape which can dry out and loose adhesion in 10-30 years.
#75
