Old 01-27-2017, 10:34 AM
Originally Posted by DavGoodlin View Post
Tom, Do I recall you passing some controlled current thru that guitar string to speed the process, like from a car battery
I initially* designed my rig to be capable of that, but did not pass any current when I did my successful Zenith type cataract removals. I initially experimented with current, but found the wire would develop hot spots, loose tensile strength and snap well before any significant progress would be made.
I've found it works best with NO current running through the wire and the wire at ambient air temp. I've also found it unnecessary for the tube to be warm...Back in fall when it was something like 45-65 F outside at night I did a guitar string zenith cat removal with the tube at ambient temp and the wire at ambient temp and it worked fine.
Make sure you attach the wire solidly to your pull handles, and to use something more sturdy than paint stir sticks. The glue will try and hold the wire/provide a good amount of resistance to pulling so it takes a good bit of arm strength.
*I've long since removed the current supply from the early guitar string cataract removal rig in my video.
The guitar string method is meant for the green halo Zenith style cataracts, the white moldy RCA style is unlikely to respond well to the guitar string method.
