Old 01-25-2017, 01:21 PM
Single transistor in the video amp section. Good solid TV. Prob work fine as is. def not one that will need to be recapped.
One thing to keep in mind when working on Zenith, there are a LOT of parts under the chassis that can be moved around (and shorted on the leads) if you are not careful on handling it. The service saver bottom removed with the chassis still installed is the way to go. May have some voltage regulation issues, IIRC on mine that was a problem. Think it had something to do with the varistor used in the regulation circuit, its not a shunt like RCA.
