Originally Posted by Captainclock
/wall of text
Also I just remembered, but how common is it for the catalytic converter to go out prematurely on a car?...
...although I think the car's fuel economy is kind of suffering because of that because I can only go about a week on a tank of gas on the car and I've kept track of the trip-odometer reading between fill ups and I'm only averaging about 215 miles on a tank of gas.
As a rule of thumb, cars are designed to get roughly 200 miles per tank. However, if you are absolutely certain you were getting more mpgs before the catalytic problem, the reverse of what you said is likely true. That the converter is suffering because of the mileage problem. Ask a real mechanic to do a good tune up and see that the motor runs right first.
