  #32
Old 12-30-2016, 12:37 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
We have liftoff!
Originally Posted by N2IXK View Post
You may have difficulty directly measuring the 3A3 filament voltage, because it is a high frequency (15.7 kHz) and pulsed waveform.
Most AC voltmeters won't read correctly on non-sinusoidal signals. And of course, if the 3A3 plate cap is connected, the filament is floating at HV to ground.
Thanks for the info, I'll keep that in mind for future reference.
Problem solved. There was a VERY loose transistor on the horizontal output board. One leg wasn't being gripped at all. I re-seated the board just for good measure, stuck a piece of wire beside the loose pin, powered on and presto, the HV was back. The picture is awful and barely holds sync in either direction, but hey, she's a runner. The piece of wire can barely be seen in the photo.
Edit: Later on it lost vertical sweep. The fellow I got it from did say it has a vertical problem.
