I used to fix those all the time. A few electrolytic caps, usually the smaller value in the primary and some in the secondary, maybe a new driver transistor, possibly replace a shorted zener that is there for overvoltage protection to the rest of the deck electronics. If it took a lightning or power surge then likely the driver transistor, fuse and the protection zener on the secondary side.
btw.. fuses are there for a reason! NEVER jump a fuse and just plug it in straight to the wall. If you must, use a 25 or 40W light bulb in series with the AC. Upon first power on after repairing the power supply I would always plug it in with a 40W bulb in series to make sure I got it all fixed.
If you do not have an isolation transformer, don't work on the power supply plugged in. Primary side is hot to AC.
