#196
I hate to say this, I feel, there's a problem with that CRT. If there was a problem with insuffient HV, there would be blooming and a change of focus with a change brightness and contrast settings. I would refrain from realigning the IF, until the other problem is resolved. IF alignment problems are normally exposed when turning the fine tuning and double images are shown in the picture and other IF ringing.
#197
I gotta concur, all signs thus far do point to the CRT re. the focus problem. Also, messing with video IF alignment would be like adjusting the brakes hoping to fix the carburetor.
And while not a big deal, there's still the hourglassing problem indicating power supply ripple.
#198
The hourglasing may also be from a large line transformer too near to the CRT...If you got one near the set move it away a few feet if you can.
#199
I varied the contrast and brightness and there is a very slight change of focus, but still way bad. |
#200
#201
No line transformer near the CRT.
#202
Tomorrow I should have my HV probe for my VTVM. Only then will I know what kind of HV I have.
#203
The meter still works great. |
#204
By the time, I needed a HV probe, I ended up buying a Pomona HV probe. It was the most common at the time. I mainly used it for color sets.
#206
OK everybody.
I got my HV probe today and assembled it and hooked it up to my KG-625 VTVM. After a few minutes warm up time for both the TV and VTVM, I zeroed the VTVM and measured the HV at the door knob connection of the HV lead going to the CRT. 12Kv. I then measured at the CRT, 12Kv again. So I'm getting 12 KV at the CRT with the "stock" assembly. |
#207
OK, I got a NOS Westinghouse 25DN6 and tried that instead of the 25CD6. I now have 14Kv! 2Kv by just using an alternate tube! This measurement was with the brightness turned all the down. At normal viewing levels I have 13.5Kv.
Still very unfocused. Last edited by Crist Rigott; 12-27-2016 at 11:37 PM. |
#208
I boosted the B+ by 10 volts and picked up another 1Kv. With B+ from 124 volts to 134 volts I get another 1KV volts from 13.5Kv to 14.5Kv under normal viewing brightness.
#209
About 20 years ago, I replaced the "C" battery and rechecked the calibration. |
#210
