Old 11-28-2016, 12:42 PM
madlabs madlabs is offline
Got the A11-12 tuning can off the parts set. I see that there is a slug that is only accessible from the bottom. I am assuming that is adjusted at the factory and only the top slug needs to be adjusted on the set. Is this correct?
While I have the PCB off again, I want to look for anything I can do while it is off. I checked C43, as I have read it can be a problem and is the only mica cap on the board. It tests fine, in the ballpark for capacitance. I leak tested it to 450V, which is as high as I can go. Should that be enough of a test?
And again anything else I can look at? My remaining issues are poor vertical linearity and troble locking the horizontal hold. One thing I should note is that I didn't have the correct value cap for C42. It is supposed to be a .0039. What I had on hand was three .0012 that I put in parallel for .0036. Think that should be ok?
Thanks!
