Old 11-27-2016, 04:52 PM
A resistor in that position can act as a slow blow fuse if a filter cap shorts hard to ground. Before blowing it protects the power transformer from over current. Basically it acts as a shock absorber.
It also makes life a little easier for the vacuum tube rectifier. Lower peak currents due to the filter cap recharging between full wave cycles at 120Hz. You can kill a rectifier tube if you have too much filter cap and too low source impedance on it. SS diodes are much more forgiving here.
