#31
Are you certain you have the correct value capacitor across the horizontal coil? Even if you do you could try changing the value and see if it brings it into range.
I think this is more an issue with the Horizontal Oscillator speed rather than a Sync problem, I would look closely around the 6K6 Osc tube, particularly cap C96 (assuming you're using the Sams?) Can you make the horizontal flop both directions or does it never reach the point of straightening up? |
#32
It never really straightens out. I can get the lines to get about an inch wide, but never straighten any further. I will look at those caps like you suggested and yes I'm using the sams. Thanks!
#33
Ok, so I remembered that some sets a horizontal frequency or locking range trimmer on the bottom of the horizontal oscillator transformer. So I pulled the chassis out and underneath a bundle of wires I found this adjustment screw sicking out of the bottom of this transformer. I hooked up all of the cables to the set,and turned it on. Adjusting this screw got this image to finally lock! Now that I have an image, I'll have to figure out why my image is washed out, but at least I have s stable image! I'll post a picture once I get my picture figured out.
#34
It seems if you turn the set off or change the channel, , the set loses horizontal sync and you have to slide the set out and adjust the trimmer again. Perhaps a 10,000pf mica is leaky around this transformer. Could I replace with a .001 ceramic?
#35
More likely the hor.osc tube is borderline weak, even though it may test 'good' on a tester.
#36
Ok, I'll try another, thanks!
#37
This is the best I can get the video. It's obviously blurry and pretty washed out. I've replaced the video output tube(6AG7) and sprayed the socket in the 1st video tube (6AG7), but it hasn't gotten better.
#38
Yee-ikes!
Has anybody played with the IFs?
#39
I don't know, geez. I guess I'll start there....any tips?
#40
Have you tried directly injecting a video signal at the video output grid?
#41
Before touching anything in the IFs, first you need to ascertain that the problem's not in the video chain, i.e., 'downsteam' of the video detector.
#42
I've been checking every resistor in the video chain with no smoking gun. Tonight I decided to check around the DC Restorer tube(6AL5). I found a 330k resistor that was many times over its value. Popped in a new resistor and was rewarded with a great picture! I've got a few caps left to replace in the separate am radio chassis and to figure out what's wrong with record player. The hardest part of this combo is done though!
#43
Put in the final caps and put it all back together. Picture quality in this set is excellent!
#44
Nice work. Those early DuMonts are the best.
Phil Nelson Phil's Old Radios http://antiqueradio.org/index.html |
