Old 10-20-2016, 07:17 AM
jstout66 jstout66 is offline
I'd say replace the obvious.
Old 10-20-2016, 08:51 AM
WISCOJIM WISCOJIM is offline
Ditto. If a tube tests that bad, it would be standard practice to replace it whether or not you suspect it of being or causing a problem in the radio performance. It's not a big investment at only $3.00.
http://www.esrcvacuumtubes.com/vacuu..._6A3-6CZ5.html
And if you are using tubes that test bad in TVs, replace them also before trying to do your troubleshooting. It makes no sense to try to work through all the components when a bad tube is so easy to replace first. It'll save a lot of hours of grief to do the obvious first there as well.
