Old 10-11-2016, 08:57 PM
If the LO (local osc.) is not running, try reversing the connections of either the primary or secondary (but not both).
FWIW, it's not "the IF" which needs to oscillate, but the LO. Think of the first two grids in the tube as a triode, with the second grid acting as 'plate'. The LO tracks 470 khz higher than the received signal. The two signals mix to generate the 470 khz IF signal.
Say your station is at 600 khz; the LO will be at 1070 khz, and so on up the dial. In fact you can use a second radio to hear the LO of the problem radio, to tell if it's tracking correctly.
Did you check that 40K resistor carrying B+ to those screen grids?
Old 10-12-2016, 05:15 AM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
Forgot to mention that, yes I did it measured 100k! I replaced it and went from 31v to my current 64v.
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
Old 10-12-2016, 09:57 AM
Chances are when you get the osc running, that screen grid voltage may come up somewhat (since the osc grid will be developing a few volts negative).
Old 10-12-2016, 06:32 PM
SwizzyMan's Avatar
This thing is driving me nuts. I've tried every possible wiring combination on this damn coil. Some bonehead was in the chassis in the past and screwed up the wiring on the filter caps and I can't seem to trace where they go on the chassis I have them in now but I don't think they are in the right place since I have to jump the B+ to another post to get any voltage at all on the grids of the 6a7 and 78. This thing is driving me nuts!
