Old 09-18-2016, 07:03 PM
It just arced over, either from dirt or moisture and time.
I'd try to Dremel out the path between the terminal and the frame, you can leave enough of the Phenolic around the terminal to support it but remove all of the charred part.
Lots of hair fine wires on that board so you'll need a steady hand with the Dremel.
