Old 09-03-2016, 04:07 PM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
Lets see, new copper pipe ground made zero difference.
I tried a lot more wire and all that did was kill the tickler, meaning it acted like a volume control and the strongest lima station stayed in no matter where I tuned the tuning cap. I added a homemade wire cap and I ended up with basically what I started with. I tried subbing with jumpers a very strong 864 tube and had similar results. A diagram online for an Armstrong 1 tube regenerative set shows a rf bypass cap in parallel with the headphones. I just tried a .022 cause that's all I can find and if you aren't perfectly on a station this set will squeal loudly. I am sure that it should be a lower value .
