right on the doubler on the rest of the roundies. There are many exceptions like aircraft carriers would often carry over the model number, some others too. Then there were model#'s with numbers at the end & the run numbers ! Screen sizes were a mix (like 40 vs 19 etc) with both some years. And System 3 triple X chassis was out in late J line TOL consoles but not known as S3's. Flat chassis was switched mid year E-line to to the upright but F-line lit shows the Avanti combo still using it !! It do get cornfusin at times....... 73 Zeno ![]() LFOD ! |
Zeno really has the mid-end of 70s figured out. I never knew what some of those letters meant beyond the year.
Many chassis numbers in the 60's ended with a Z, which must mean something special. TUD - if you know the post 1971 years, then I offer the rest of the story. feel free to jump in on this all you Zenith fans out there, I am only but one of many here ![]() I'm probably leaving a few smaller color chassis out... but here are the chassis numbers from the early glory years 29JC20 was the first in 1962, few here are lucky enough to have one in their collections 27KC20 second chassis - 1963 - consumer reports notices Zenith has so few repairs and no need for "factory service" 25LC20 and 25LC30 Third chassis - 1964 (my personal favorite as I have a Space Command and we are the same age) 25MC30 thru 33 fourth chassis - early 1965 24MC30 thru 32 fifth chassis - mid 1965 - narrow HV cage on top of chassis, uses 6Z10 instead of 6BN6 and 6BQ5 for audio det/out tubes 25MC36 first 25" rectangular (25AP22 CRT) chassis - late 1965 ***** Zenith is pounding the competition at this point, RCA suffers but not like some others **** 24NC31 last roundie chassis - late 1965 lower cost alternative to a 25" rectangular with legendary durability 25NC38 second 25" rectangular 20XC36 thru 38 (aka 20X1C38) 19"?, 22" and 25" - 1967 many models (I have the full-line 1967 brochure )15Y6C15 first 15" color chassis 1968 a bulletproof heavy bastard ![]() 20Y1C36 thru 48 - 19"?, 22" and 25" 1968 14Z8C50 19" and 16Z8C50 22" thru 25" 1969 14A9C50 19" and 12A12C50/52 22" thru 25" 1970 - SS IF strip and color demods, tube count drops 4B25C19 1st 4-tube hybrid 19" 1971 - not sure of other 19" and under 12B14C50/52 - 25" and 25V" 1971 - still using tubes in VHF tuner *****1971 was last year for tube count as first number***** 14CC14/15 14" sets 20CC50 19", 25CC50 22" and larger 1972 19DC11/12 19" 4-tube hybrids 19" 1973 25DC56/57 the first all-transistor and IC modular chassis for 25V" models 1973 23EC15 the last four-tube hybrid (except 25V") budget 25" models 1974 25EC58 2nd all-transistor and IC modular chassis for 25V" models 1974 17EC45, 19EC45, 23EC45, 25EC45 the first "vertical chassis" series used from 1974 thru 1978(?)
"When resistors increase in value, they're worthless" -Dave G Last edited by DavGoodlin; 10-17-2016 at 04:00 PM. Reason: add 17EC45 et al - revise 25MC36 and 25NC38, corrcet 15Y6 |
BTW: I am one of the 'lucky few' 29JC20 owners.
Foggy memory but IIRC 15Y6C15 was the first 14" Zenith. A tin can set with a console chassis stuffed in. Probably the first to use
the IF module & drive the tube count by 3. Ball buster to carry but it did have a handle. Someones sick sense of humor....... First SS set was C-line 25CC55 IIRC. Big difference was it used a pass regulator instead of the self regulating transformer. Also there is a schematic for a B line SS set in one of Zeniths CM's. Probably never sold, maybe a test / show set. 73 Zeno ![]() LFOD ! |
