Originally Posted by dieseljeep
You have one of those things as well!
The main reason, I bought it was the novel volume control circuit. Most of the tubes were missing and the cabinet is missing some veneer. I did get it going, but it needs restoring and Aligning.
I got it for $45 at the last WARCI meet. Mine is near perfect see pic, and has seemingly all it's original tubes*. Some of which are REAL odd early shouldered envelope metal types the likes of which I'd never seen before. I bought it because in the early years a console with the same dial (which I like the look of) slipped through my fingers, and this was a chance to have "the one that got away" in a nicer package.
*So when I found a P-K short in the 84 (proto 6X5) rectifier I got creative, and added diodes under chassis, cut the tips off the P and K pins and slipped spaghetti between the envelope through leads and the inside of the hollow pins...The heater is still connected, original tube in socket looking correct from topside, but no more pesky P-K short.
DSCN1992 by
Tom Carlson, on Flickr
