Old 08-04-2016, 10:12 PM
Ethical dilemma: Do I scrap an Admiral to fix a Predicta?
I scored what amounts to a $20 Predicta Debutante with an original Philco 17DAP4 CRT that has an open heater.
DSCN2002 by Tom Carlson, on Flickr
I have about $25 in an Admiral I have in working order which has a 17DSP4 CRT that I believe would fit the Predicta.
This Admiral ain't exactly rare (I've seen at least 2-3 others), or valuable.
Do I kill it to get the Predicta to live?
I also have a potential source of a good used and or NOS CRTs for it, but odds are it is going to cost me ~$60-200 (need to talk with the seller more) for one. Should I pursue that instead?
There also is potion C: pop the admiral CRT in the philco, make the philco work (if it can), then (if successful) get a new jug for the philco and return the admiral CRT to it's original set.
What say you?
Old 08-04-2016, 10:38 PM
radio63's Avatar
radio63 radio63 is offline
Still Y2K Compliant!
Nice Admiral TV! And a nice Philco! In my opinion, I would see first about getting the other CRT that you said was available. If not, and you really want to get that Predicta rolling, I would take the CRT out of the Admiral but don't scrap it. Maybe you can find another CRT for it later on. I always try to not scrap out something that is working, such as your Admiral is. Just my opinion on this. Good luck and nice haul!
I don't know anything about ignorance and I could care less about apathy.
www.galaxymoonbeamnightsite.com
Old 08-04-2016, 10:43 PM
maxhifi's Avatar
maxhifi maxhifi is offline
well. Which one do YOU like better? Make that one work.
Old 08-05-2016, 05:20 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
I would.
Old 08-05-2016, 07:57 AM
Mre12ax7 Mre12ax7 is offline
The 17DSP4 may not be the best chioce.
It has a 11 1/4" neck the original is 10 11/16"
You want to look for these
17DAP4, 17DEP4, 17DKP4, 17DRP4, 17DTP4, 17DXP4, 17DZP4.
I say leave the Admiral alone.
It works the Predicta doesn't.
Old 08-05-2016, 09:46 AM
What say you?
Hang loose for a little while. I'll see, if the 17" CRT I have in an RCA portable is good. It has the odd-ball 8.4 volt, 450ma heater, but that could be worked around.
BTW, the pin-out is different on the Philco CRT, vs the Admiral tube.
Old 08-05-2016, 09:54 AM
Old 09-16-2016, 08:57 PM
I've had some success repairing open heaters by zapping them with a high voltage source. A neon sign transformer seems to work well (60Hz iron type, not electronic). It has enough current to weld a small gap, but not nearly enough to burn out the heater. It often takes several tries before it will hold, so don't give up if it doesn't work at first.
I tried that using a Zenith color as a source. B+ nothing, 1+KV boost nothing, damper lead that killed a DMM I once touched to it by accident....That made a nice consistent blue arc inside the CRT, but nothing like a weld (even with banging on the neck)...That tube is toast.
Old 09-16-2016, 09:27 PM
Gents lets all remember that Toms debbie has a power transformer in it. So the RCA jug with the 8 volt heater is not going to work, a 17 inch jug from a kcs 126 will work with a little rewire, which I have done now with six Philco sets with the 10L43 chassis. All the the best, Tom J from Fla
