It is fine to replace the 10V caps with 16V caps. The zener diode will read close to 0 in both directions if it is shorted. Otherwise it will read around 0.7V (using the diode check range on a digital meter) in one direction and open in the other. In circuit other components around it can effect the reading. If you're unsure unsolder one side of it and test again.
