Old 07-06-2016, 02:40 AM
wkand's Avatar
wkand wkand is offline
You said it, electrolytic... waviness in pic is usually a bad filter cap.
Old 07-06-2016, 08:48 AM
tighten up the screws that provide the grounds to the sweep board. may want to clean up the chassis a bit under the screw head. Its is for a very slow wave like 20-30 second to work thru. I think its a beat freq of the AC line freq to the vert sweep freq. Had an old Maggie with screw mounted sweep that nearly drove me nuts. IIRC I finally figure it out by power the heaters up with 6v DC that cured it, so I knew it had something to do with line freq AC modulating the sweep and not the B+. I then confirmed it was the AC heater to the sweep only by only using DC on that board. the key word hear is the VERY slow humbar. I ended up soldering a ground strap from the sweep board directly to the chassis so I did not have to rely on the pressure of the screws making the grounds. Of course checked for HK shorts 1st.
