Look in Sams & see if it shows resistors & or caps
mounted inside the yoke. Compare values. Also someone here has the factory manual, check that too. Keep in mind a slightly weak damper, output or osc tube can do this & not show BAD on a checker. 73 Zeno
Well, all that for naught...just looked at the old yoke again, and it is the 95-1768.
Zeno, I do have the factory service manual, it is what contains the conflicting data. |
