Old 06-09-2016, 06:29 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Probably has to do with the year it was first available-1969. I don't think there was a reliable solid-state substitute yet.
In 1974 I went to work for Varo Inc. and among the things they manufactured were solid-state high voltage rectifiers and triplers for TVs. By then they were reliable and common.
Old 06-09-2016, 07:21 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Varo pretty much owned the market on those things, didn't they? I think they were the first to produce them. I agree the 1969 introduction of this model would have been just a bit early for SS. I assume the GR2000 series sets used a solid state HV rect or tripler?
I have an ECG solid state replacement here which I think would work in this set should the 3CU3 ever give problems.
Old 06-12-2016, 10:28 PM
N2IXK's Avatar
Technohippie
Onto the next assembly manual, covering the assembly of the Tuner cluster/Control panel. The manual is divided into 2 sections, and the builder follows the half with or without the remote control option as applicable.
Work starts out as more mechanical assembly. The VHF and UHF tuners come preassembled, and are mounted into a metal subchassis. The tuner drive motor and gearbox get attached, along with numerous terminal strips and a large oil filled capacitor (4 uF, 370V) used for reversing the tuner drive motor. The supplied capacitor was a Sprague "Chlorinol" capacitor, which was a trademark for polychlorinated biphenyl, or PCB. Although the cap looked pristine with no signs of leakage, I replaced it with a modern non-PCB cap to remove the environmental hazard. The new cap fits the original mounting perfectly and looks original to the set. The original cap is safely stored away for the next hazmat collection day.
All the pots get attached to a bracket, which is then mated to the front subpanel and the tuner chassis, completing the mechanical assembly. Because I am installing the remote option, drive motors get installed onto the back side of the color and tint pots to allow remote operation. The UHF and VHF channel indicator dials are backlighted by incandescent lamps, and driven via a small timing belt drive. The VHF fine tuning is driven with a ballchain drive system. 4 pushbutton switches are installed for power, channel up/down, and UHF/VHF select.
The wiring is almost completely prefabricated harnesses, which are quite long and make for a real pain on the bench. The unit ends up with quite a wad of wiring attached.
The final part of the assembly is the stuffing of a small PC board which they call the "UHF" board, but what it really handles is the switching between UHF and VHF tuners, and driving the appropriate dial backlight for the selected band. The board is connected to the chassis via a 15 pin Molex connector which supports the entire board. While Heath sent a 15 pin Molex connector which I dutifully installed, It wasn't until trying to plug the board in that I discovered that the WRONG GENDER of connector shell was supplied! Luckily, I had a proper connector shell, as well as the pin extraction tool to remove the contacts from the supplied shell, and reinsert them into the proper one. The board survived the desoldering and resoldering just fine, and the tuner cluster was completed in 3 bench sessions totaling around 5 hours.
Old 06-12-2016, 10:30 PM
N2IXK's Avatar
Technohippie
More pics.
Up next--Installing the CRT and bringing all the parts together for final assembly!
Old 06-13-2016, 07:36 PM
N2IXK's Avatar
Technohippie
Onto book #4, covering assembly of the CRT, mask, and chassis frame.
I began the process by building a temporary "T" extension (3/4" plywood and 2x4 legs) onto my workbench to provide enough room to work on the assembled set. Most of the projects I tackle in my shop are a good bit smaller than this beast!
First up, I decided to actually test the CRT to make sure it was still electrically good. The CRT carton was pretty well destroyed by moisture, and the tube itself has a nasty cataract extending 3-4 inches in toward the center in a few spots. Assuming the set makes a good picture, a cataract removal or (preferably) a CRT replacement can be pursued later. The supplied tube is an RCA 25VABP22, but the manual refers to a 25VADP22. Comparing datasheets shows the tubes are pretty much identical, with the later VADP having a "Temperature Compensated" (Invar?) shadow mask for improved purity. I seem to remember that most of the 25V-series tubes were fairly interchangeable, with minor differences like black matrix, rare earth, mounting ears, etc.
Firing up the tester, the tube was a bit slow to warm up after sleeping all these years, but after a few minutes warmup the guns balanced perfectly, with emission and life test readings consistent with a NOS tube.
Assembly begins by placing the plastic CRT mask face down on supports (4 blocks of 2x4), and lining the inside of the mask surface (where the edges of the CRT faceplate rest) with aluminum foil tape as an electrostatic drain. The provided roll of 3M foil tape was still perfectly usable after 4 decades in storage. The foil is carefully overlapped in the corners, and folded over to make contact with the CRT mounting hardware.
The CRT is then placed into the mask opening, making sure that the anode contact faces the top edge of the mask.
The CRT clamps and straps are prepared by adding adhesive felt pads (also amazingly viable despite age) and rubber cushions at the points where the clamps bear against the glass. the clamps are carefully drawn down tight in several stages until they bottom against the mask, then the strap screws are tightened to clamp the tube into place.
A long length of bare solid wire and a coil spring are installed as a grounding contact for the outside dag coating, and the degaussing coil is wrapped around the tube in a very carefully specified pattern (to assure even magnetic field over the mask area), and anchored in place with cable ties.
Next up--final chassis assembly and moving toward "First Light"....
