I moved my Zenith Chromacolor today, and since I did not have very much help, I had to remove the picture tube to lift it. Now, it's in its new home, and I CANNOT get the degaussing shield to go back on correctly. When I took the bolts out, I heard a POP and the degaussing shield shifted, and I can't get it to go back anywhere correctly.
I'm making slow progress - I got two corners (bottom left and top right from the photo's perspective) but now, the shield hardly moves at all. I can't get it to reach the other two corners.
Do you see the straps on the sides of the shield? Unscrew the straps from each other and the shied will unwrap it's self from the CRT. Lift CRT from the shield. The proper installation order is to put the shield in the cabinet, bolt the shield corners down, set the CRT in the shield from the rear, fold the shield around the CRT and tighten the side straps of the shield.
Hope that makes sense.
Yup. I remember being annoyed in the process of learning that method by my own guess work a few years back...It's clever and works well, once you know how to deal with it.
OK - I got the degaussing shield bolted down and the straps unbolted. I have the pieces of the shield restrained with some thin wire to hold them back, but the CRT is too fat to go in! I don't want to force it. Should I?
Good News! I found out what the problem was. The degaussing coil itself was in the way. I moved it and the CRT fell into position perfectly. All I have to do now is align it. I sure am glad I watched all those alignment videos on Youtube. I'm pretty sure I'll be able to handle it. Now that I have that spiffy Sencore NTSC generator, alignment should be a breeze compared to this tube fiasco.
Next time wait until a friend can help you move it
Nobody ever helps me with anything. I have to do everything by myself. I couldn't even get my mother to come LOOK at the set.
