My interpretation.
1. Set IF amp grids to -3 by use of picture control or external bias supply if needed. 2,3. Max indication = highest (in this case voltage) reading the circuit will give your meter while making the adjustment, and Minimum indication is lowest indication circuit will give. (I'm surprised this is confusing.)
