Old 04-03-2005, 08:03 PM
RetroHacker RetroHacker is offline
Electronics Accumulator
I've never seen a hospital or motel set before, but I once saw a tube set that was sold to schools. It was really neat - it was black and white, and very well made looking, a more industrial look to the cabinet, and a video input jack! Unfortunately, the set I found was totally trashed, it looked like it had been thrown from a moving vehicle. It was smashed and bent, the tube was broken, and the back knocked off. The chassis was bent on the side, and it looked like the power transformer had broken off partly. It looked to be line isolated - probably for the video input modification, and it also had a headphone or audio output jack.
Really too bad that it was so broken - I scavenged what intact tubes were left, but the thing was really beyond any hope of repair. Never seen another one, but I'm still hunting. The video input jack opens up all sorts of possibilites of usefulness. Not sure how the video input was wired, it had a switch, and I would assume that it was just patched in at the grid of the video amplifier tube, disconnecting the last I.F. stage and biasing the incoming signal properly. I've modified tube black and white sets to take composite video before, but the biggest problem is getting good isolation from the TV's chassis - the ground is fairly simple, a polarized or grounded cord or an isolation transformer - but depending on the set, the bias voltage is high enough to interfere with whatever is the source of your signal.
-Ian
