Untested it is not worth more than $50 (so don't loose your but buying it). Vacuum tube based TVs (IE most sets pre-1973) even if working will need annual maintenance if used more than a couple hours a week. Learning to solder and do repair work is important if you wish to make such a set a high usage/daily driver set.
When you get it find the chassis number (on RCA: color number is CTC-## monochrome is KCS-## ) then get the photofact folder (don't buy it from sam's tech publishing their prices are a ripoff)....It is like the Chilton's auto repair manual of the TV world. You should also get a cheap DMM and buy or get access to a tube tester and a CRT tester. These sets can usually be repaired cheap, but sometimes can be expensive to fix. The CRT and flyback are the two most expensive parts either will run you close to $100, but it is not common for them to be bad and usually one is good. If one is shot you could reclaim your purchase price by parting the set out.
