Old 05-18-2016, 04:40 PM
TUD1 TUD1 is offline
Best way to remove 2nd anode goo?
I went to the glue the label back on my Zenith Chromacolor's 25VBQP22, and I remembered that I was supposed to get all the goo off the 2nd anode, but I kept forgetting to ask how. So what works best?
Old 05-18-2016, 04:48 PM
MRX37 MRX37 is offline
Goo Gone?
WD-40?
Old 05-18-2016, 05:17 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
Acetone or a hydrocarbon solvent like "Goof Off" or lighter fluid should work. The "goo" is silicone grease, most likely...
Old 05-18-2016, 05:29 PM
I'll try the Goo Gone first - I've had good luck with that stuff. If that doesn't work, I'll try Goof Off.
Old 05-18-2016, 06:01 PM
Acetone and a rag should work.
Make sure to test the rag first or you'll dissolve the rag as well.
Old 05-18-2016, 06:11 PM
Old 05-18-2016, 06:17 PM
Lighter fluid should work well, just be sure the tube is discharged, sparks and a rag full of lighter fluid is not a good combination.
Old 05-18-2016, 07:33 PM
N2IXK's Avatar
Technohippie
You will want to avoid getting the solvent onto the external dag coating, as well. It will easily dissolve, and potentially leave conductive residue on the bare area around the anode button.
Old 05-18-2016, 07:59 PM
Thanks for the information. That would be pretty critical.
Old 05-19-2016, 10:05 AM
We always used 91% isopropyl alky & paper towels.
Old 05-19-2016, 06:04 PM
I used the alcohol and the goo just dissolved away. I highly recommend this method.
