Old 05-04-2016, 02:18 PM
rca2000's Avatar
rca2000 rca2000 is offline
Going 15-20 years with NO service? I challenge ANY flat-panel..of ANY format--to even THINK about that !!
most--particularly those made within the last 6 years or so....are DONE...by 5 years...If they have not been BROKEN by then.. The last 3 flat-panel sets I acquired ..one was broken,(but could NOT be seen until powered on) one, a Pan a plasma, had bad address chips on the panel ribbons, the Mits LCD, an EXPENSIVE 08 model...had a bad "tab bond", making it irreparable..
You had to TRY to break a picture tube...lust lean against most LCD sets...and GOOD_BYE !!
Old 05-04-2016, 10:19 PM
I was not talking about 15 to 20-year-old flat screens. I was referring to CRT TVs which do, more often than not, last that long.
Where did you get this "five years" figure for the lifespan of flat screen televisions? I have a 19-inch FP in my living room that is very close to the five-year mark. I use it daily, and it is working every bit as well as when it was new.
While it is true that flat screen TVs can be damaged by knocking or pushing them off their stands, I seriously doubt that just leaning against an FP will destroy it. I think you may have been taken in by all the old wives' tales that started when the first FPs were available, including the one that stated most FPs last only two years. This may well have been true of the very first flat panels, but the technology has improved greatly since then. Today's flat screens, with the possible exception of the no-name sets sold in discount stores for under $100 (these are often found in pharmacies like CVS, Rite Aid, et al. as well), are generally quite reliable and will last quite a while, if not manhandled or otherwise abused.
The brands of FPs most likely to fail within two years or less are the no-name ones, such as Polaroid and others, with names no one ever heard of. The website for Insignia TVs (Insignia is a house brand of Best Buy) states clearly that their flat screens are of superior quality, which I believe since my own Insignia set has lasted almost five years and shows no signs of impending failure. Further, I find by looking at the support forum that most of the troublesome sets have very large screens, 32 inches and larger; I rarely see any support requests for Insignia FP televisions with screens under 20 inches diagonal measure.
I maintain that many if not most FP failures are due to abuse, such as being knocked off their stands or objects being thrown at them. I once read on Insignia's FP support site of a set which had a cracked screen caused by someone throwing a wristwatch at it, and it would not surprise me if a lot of FPs are damaged beyond repair during football season by people getting angry because of a bad call, or by kids throwing a football in the house and said football hits the TV screen, cracking said screen instantly.
Where is it cast in stone that any flat screen TV from a reputable manufacturer, given the proper care, will not last more than five years? I realize these TVs will eventually wear out like everything else, but on the other hand I do not think it is fair to put a definite number on the length of time, in years, the TV will last before it fails. As I said earlier, the very cheap, no-name FPs found in discount stores and pharmacies may not last longer than a year or two, but sets bought from reputable stores such as Best Buy should last indefinitely. There is an axiom in the TV service business (and probably others as well) that states if a television, for example, still works well after the warranty expires, said TV will continue to operate flawlessly for some indefinite length of time afterward.
This is not to say these TVs will never require service at some point in their lives, but I am sure the reliability of most flat screens is good enough that it does not pay to even think, much less worry (!), about when they might fail. I for one am not concerned about that. If my FP eventually does fail, I have a 20.5-year-old 19" Zenith table model CRT TV, that still works as well as when it was new, that I can put in its place within perhaps a half hour.
BTW, I recently read, I believe it was in this forum, that CRT televisions actually make better pictures than FPs since CRTs use scan lines, rather than pixels, to form the pictures. I am wondering if CRT sets used with digital cable or with Rokus or other streaming video players are immune to the pixelization seen on FPs when the signal is weak.
Old 05-04-2016, 10:45 PM
rca2000's Avatar
I was refering to experience from about 14 years of working on them. having seen the sort of problems they have. having seen SCADDLES of broken ones--often from only minor impacts. having seen a LOT of bad panels, Backlights...ESPECIALLY LED BL'S, and a LOT of bad tab-bonding problems on LCD panels..
Give me BACK a CRT---maybe the FACT that they last SO long and are SO durable--when done right... (like many RCA CRT"s and Zenith CC tubes)..is one reason they KILLED them !!
