Old 05-03-2016, 08:30 PM
Banned
Yes that might help, if you can get a clear shot.
update: looks like you should be able to get to the terminal on the other side of the board and measure it... or unsolder it if necessary.
Well I measured the fuse and it seems that it might be open possibly because it measures about 2 ohms and not 0 ohms like you said it should if it weren't blown. good news is that the fuses this thing takes are still available over at mouser for like 11 cents a piece. So it shouldn't be too hard to replace the fuse (although they have the fuse glued into place with that nasty white glue that turns to a rubbery consistency when it dries so it will be tricky to try and get it out of the circuit without damaging the circuit board traces.) What's a good way to get rid of that glue without damaging anything?
