You can get all you want from the stock chassis/CRT. Replace the caps, get strong tubes in it, add a cooling fan to the fly and chassis, and it should live as long as the CRT. Most Zeniths are easy to add a composite video input to...Just add a switch or (better yet) relay after the video detector diode to switch between the diode and your input. Having a spare set on hand is advisable when using tube sets as daily drivers....I generally run 2 at once so if one dies I can turn it off and finish the program on the other set.
I've used the crap out of my 1971 Zenith CCI 11 tube hybrid...It has been a daily driver for about 6-8 years and it has been decent, except for a couple of annoying issues related to parts your set is probably too old to have. It has had at least 4 hours a week and some months has had 8 hours a day every day.
jr |
If I did not like comparing images I'd probably only run one at a time to use less power. A Zenith of that era would probably be good for a 1-1.5 years on average between repairs with poor cooling, add fans to the chassis and don't let the room it is in get too hot and you could probably double or triple that.
